hi all, i've been flying helis for years decided to go flybarless. 600 flybarless head and tarot xyz. all seems ok on ground but when i get near take off speed the swash keeps going hard right. if i manage to get past this and hover (really hard) seconds into the hover the heli goes into a frantic woble. any ideas? i seem to have tried eveything and the head etc looks perfect.
tarot xyz and flybarless 600
Roger,Originally posted by roger View Posthi all, i've been flying helis for years decided to go flybarless. 600 flybarless head and tarot xyz. all seems ok on ground but when i get near take off speed the swash keeps going hard right. if i manage to get past this and hover (really hard) seconds into the hover the heli goes into a frantic woble. any ideas? i seem to have tried eveything and the head etc looks perfect.
Hard aileron movements are usually caused by vibes - how smooth is it? How good is the tracking? Oh and how is it mounted ? they prefer to be pretty firmly mounted.
What firmware in the ZYX - the latest 3.5 is much better IMHO, but you need to drop teh D values on the swash to 10. Can you post your .ini file to see if there is anything obvious.
Mike
Hi Roger.
I fly a 600 nitro using a Tarot zyx and am very pleased with it. Is yours a nitro?
When I first tried mine - using the settings that work nicely on my 450 - it frightened me to death - shake isn't the word!
I had to dial the settings right down on the advanced screen and also strap the FBL unit down very hard. Its mounted on a gyro pad and then pulled down hard with a cable tie through fuel tubing.
I can let you know what my PID settings are if it helps.
BTW, Mikej is the man in the UK for ZYX advice so keep sweet talking him
__________________________________________
Dave
T-Rex 600E - BeastX -
T-Rex 550E - BeastX
T-Rex 450 PRO - BeastX -
T-Rex 250 - BeastX -
DX8
From what he describes I doubt it's tail shakes that are the problem, it'll be whole body shake! Needs to drop the Roll&Pitch P value down to about 30 from the 80 where it probably is now.Originally posted by debrooker View PostOn my GAUI using the recommended servo ball positions I was getting the same, I ended up moving the servo ball positions in.__________________________________________
Dave
T-Rex 550E - BeastX
DX8
Dave,Originally posted by davew View PostFrom what he describes I doubt it's tail shakes that are the problem, it'll be whole body shake! Needs to drop the Roll&Pitch P value down to about 30 from the 80 where it probably is now.
Are you sure about those figures? Keeping the P value closer to 80 and dropping the Gyro Total Gain for Roll and Pitch down to 30ish is more common.
Mike.Last edited by Mikej; 29-09-2012, 02:55 PM.
sorry should have been clearer, i was referring to the cyclic servo ball positions. At the recommended distances I found that the available throw was enormous, so I reduced by moving balls in.Originally posted by davew View PostFrom what he describes I doubt it's tail shakes that are the problem, it'll be whole body shake! Needs to drop the Roll&Pitch P value down to about 30 from the 80 where it probably is now.
Using the servo wheels on the Align DS610 servos you are stuck really with the ball position, ie servo arm radius. It could certainly manage with a smaller redius. On my 450 I dropped the servo arm radius down from 13mm to 10mm and definitely benefitted.Originally posted by debrooker View Postsorry should have been clearer, i was referring to the cyclic servo ball positions. At the recommended distances I found that the available throw was enormous, so I reduced by moving balls in.__________________________________________
Dave
T-Rex 550E - BeastX
DX8
Hi Mike,Originally posted by Mikej View PostDave,
Mike.
On the 600 nitro I have the Pitch and Roll Gyro gain on the front page at 30
On the advanced settings for Main Rotor my P.I.D settings are 30 75 30
The reduction to 30 P value was what got rid of the body shakes. Picked it up from postings on Helifreak where zyx use in the USA is more common on nitros. dave__________________________________________
Dave
T-Rex 550E - BeastX
DX8
That's interesting Dave, thanks for explaining.Originally posted by davew View PostHi Mike,
