Unexpected Auto and heavy landing, now have vibration following boom strike Trex 600
  • Unexpected Auto and heavy landing, now have vibration following boom strike Trex 600
    Hi guys,
    Some thoughts if you would be so kind!
    I and still learning and at about 30-40 feet slowing to a hover, a fuel problem shut the engine down........
    Well I can vouch for the value of Phoenix Simulation, as I practice autorotations, and I "saved" the day at the last few feet, but had a fairly heavy landing with the "clack" of a boom strike, evidenced on inspection on the tailboom.
    I changed the tank fuel line which was the cause of the problem (split just beyond the nipple, so I could see 1/3 fuel in the tank but the hopper was emptying which I did not notice!) and today went for a flight.
    On throttle up.... you know it just did not seem right, at about 2/3 head speed got a fair bit of vibration, then some tail wagging, and the sound was different, almost resonant compared to usual. I hovered a bit but the vibration was there as was the really twitchy tail.
    Older and wiser as I is, I landed and shut down and had another much longer and harder critical view. The only thing was that the feathering spindle appeared to have a bit of play in it, maybe as much as 2mm if you grabbed the blade holder and wagged, I have the grey softer dampeners in currently......
    Our club expert (and totally brilliant nice guy Dave) had a look for me and we thought best to look at the feathering spindle first and then maybe the main shaft.
    I am going to do this him being the expert etc, but just wondered if anyone else may have some thoughts?
    Gaz
    well from experience so far I would check all your gears auto rotation gear and umbrella gear as well in the tail box ... you could miss a tooth here or even slight wear will cause the same ...
    Sev
    Thunder Tiger E700 BD3SX
    Trex 450L DFC BD3SX
    Trex 150 PRO DFC
    Blade Nano CP X
    Blade mCP X v2
    Blade 130X
    DJI Inspire 1
    DJI Phantom 2 iOSDmini
    EMAX 250 Pro V2 FPV Racer
    Futaba 18MZ
    MK Heli Club MKMAA
    Proud Owner of:
      Good advice and all in order after checking!!!
      Thanks R4nDoM
      Gaz
