x400's got problems!
  • x400's got problems!
    hi guys,
    got a video of my crazy x400 to show you, hope you can help me out with it!
    http://www.rcheliaddict.co.uk/videos...1ed0ff613f563b
    the spec is. align430l motor / align bl35x esc / mini pred gyro (hs 56 on tail) and mini pred servo's! / min pred tx/rx / cheapo batt
    some close ups,
    tom
    who gave you that pile of dung!
    looks like glitch city to me mate . ally frames !!have you got a ferrite ring on the rx wires?
      lol its no pile of dung now boggie!
      i have been on the chat room all day and sorted it out! flies much better now
      here's a video, but by the time we had fixed it,, it was dark and the battery was dieing so its not great,....
      you can make out the ping pong balls etc...lol
      http://www.rcheliaddict.co.uk/videos...50293adfecb7b1
      will get a good video and sort out the little bit of tail wag tommrow wen there's some light!
      cheers,
        nice one Tom that looks much better im glad its got you flying again
          Yip was a routing problem for all those that were intrested.
          Shuffled a few things around... RX at the back of the heli away from metal frames/ESC away from motor and gyro mounted above boom as nowhere else to put it.
          Lee
          Lee
          www.raptoruas.co.uk
          www.lee.rcha-uk.com
          www.gensace.de
            nice one lee . that chat room is good for one on one help so it was just glitching then??
              yep was glitching!..... the chat room has saved me some phone bills!
              just took some pics of the new lay out.....
                pics for chat room discussion........ (is the gyro mount'd good enough? )
                  I would have thought that cable tie would have transfered any vibrations straight to the gyro case?
                  Regards,
                  Jason
                    Hi tom
                    I had a piece of wood stuck to the bottom inside the frame, and put thr gyro there projecting slightly out of the back of the frame. It might still be there on the frame I sent you (the wood not the 401!).
                    One possible problem with your gyro mount is it doesn't look quite square to the main shaft. It is important that it is or it will read a little bit of yaw when the heli rolls etc. Not so important for gently hovering but very important for aerobatics.
                    Glad you have it flying!
                    Are those Z bends on the servo arms? The perfection police will have you banned from this forum for posting pics of Z bends!
                    (when you use the ccpm setup you get lots of spare ball links to play with).
                    I take it you are running 35Mhz then....
                      after many complants.....i have de cable tied the heli and so
                      updated pics.....
                        Have you had chance to try it yet?
                        Regards,
                        Jason
                          not since the video of it in the dark no.
                          will fly it tommrow and film it!
                          cheers,
                            first vid nearly had me spit tea all over my laptop
                            Sponsored by CSM, Optifuel
                            Your RC Heli World
                              To be honest I did the same when I watched it last night..
