Align BL70G setup question
  • Align BL70G setup question
    Hi All.
    Been trying to setup the Auto bail out on vbar but having trouble getting the Vbar to talk to the ESC properly.
    Then I got thinking the Align ESC has a soft start but at some point you get above the soft start and the throttle response setting takes over and the soft start no longer has an effect.
    So the question is does anyone know where this point is and what triggers it? I assume it is just a certain speed of the motor at which the soft start gets over ridden.
    If I can work this out and it is low enough then should be able to set the Auto bailout up in a similar way to the Vbar by having a idle mode while practicing Autos.
    JR XG 7
