Vbar Gov spool up Video
  • Vbar Gov spool up Video
    ok just uploaded a video. Im sure that will answer a lot of questions. I don't think it is that far wrong. Just a little concerned about the spool up speed.
    Trex 500 Vbar Gov test - YouTube
    Get to about 1500 RPM in 6 sec then paused for a couple of seconds then went to 2040 approx in a total of about 8 sec ( which is max for what I had set). Noticed also that the actual speed jumps to about 4 x the requested speed. The requested spool up seems fairly smooth but the actual speed jumps, pauses then jumps again.
    I did test by moving to mid stick in normal mode then flicking through to idle 1, idle 2 for bail out then back to normal and moved the stick back to zero.
    Throttle curves are normal, 0,87,87,87,87 idle 1 95% flat idle 2 40% flat for bail out. Max head speed 2700
    The auto bailout seems to be working fine just seems to take 12 or so seconds to kick in. Flicking back to idle 1 seems fairly smooth for a fast spool. sitting on my table and didn't budge when flicking modes. No blades of course.
    Keen to see what you think. Just the spool up is a little concern. Everything else seems to be working great.
    JR XG 7
    I had a similar problem with mines when I was setting it up and what it was I had
    To update the CC esc to the older version of the software so if ur using the CC esc u should try that
    Do what u do best
    DX7 and DX8
    Phoenix sim
    And plenty of spare parts
      using the standard align one. I dont think any options to change the software in it. :-(
      JR XG 7
        Mine does the same ... on 1st spool up it gets to about 40% ... pauses for a second ... then spools up to my desired speed....
        I'm using a YGE esc ... dunno what it is
        Gaui X4 II VBar - Trex 500 efl Pro VBar
        Spektrum DX9
        My Helifleet
          Well maybe u need to put the alight esc in airplane mode!
          Do what u do best
          DX7 and DX8
          Phoenix sim
            I have put it in Airplane mode as per the instructions. Just a little nervous putting blades on and spooling up in case it is too fast. I have an old set that are 99% ok so might put those on for a test.
            JR XG 7
