JR DSX 11 switch assign?
  • JR DSX 11 switch assign?
    I want to swap the throttle hold to the switch just in front of it for easier access. How do you do it???? Looked at the manual and just can't seem to do it???
    Dji Phantom
    Go into system settings
    select device select
    Go to TH and assign to the switch of your choice
    MARK
    LOGO 500 V-BAR v5.2
    GAUI X4ii
    PROTOS 500
    MINI PROTOS 6S (stretched )
    GAUI X3. 6S
    JR DSX12
    14SG S-BUS
    proud owner of 2 x EGS
    www.bmmfc.com
      Tried that but still does not work? I'm doing something wrong but not sure what. I've done a little video to see how I'm doing it. The orange switch is the one I want as Throttle hold....
      http://www.youtube.com/watch?v=92LPD5rUiSc&sns=em
      Dji Phantom
        Is that front left switch you want to use rudder DR or any of the aux switches ??
        sorry don't own an 11 ,only a 9 & 12,
        MARK
        LOGO 500 V-BAR v5.2
        GAUI X4ii
        PROTOS 500
        GAUI X3. 6S
        JR DSX12
        14SG S-BUS
        www.bmmfc.com
          Go to divice select high light aux6 then just move the switch you want and it will do it for you.
          Trex700n
          Trex700E FBL
          Trex450pro
          velocity50
          velocity 90 / Beastx
          JR 11X
          member of the widnesflyers
            That's exactly what I did in the video? Is it the highlighting bit I'm doing wrong?
            Dji Phantom
              I think it's DR.
              Dji Phantom
                When i do the same as in your video my 11x changes to rudd sw and is the same as yours.
                Trex700n
                Trex700E FBL
                Trex450pro
                velocity50
                JR 11X
                  Think i have it, go in to thro hold in the list then switch sel and change the rudd and unselect the hold.
                  test it on the mspx it works.
                  Trex700n
                  Trex700E FBL
                  Trex450pro
                  velocity50
                  JR 11X
                    I think i followed your instruction correctly but still having a problem assigning it? I thought this was one of the new simple features Horizon Hobbies where touting? It's not.....
                    Dji Phantom
                      What you're doing there is assigning the AUX 6 channel to the throttle hold switch - there is no "aux 6 switch'. You have to go to the throttle hold menu and do it from there - so leave it as is then go to the TH menu and assign the throttle hold to the aux 6 channel. If I'm wrong I'll be able to let you know in a few hours when I have my DSX11 in front of me.
                      Gaui X5 - Spartan Vortex
                        Taken some photo,s of what i have done :-) ( three way switch on the rudd).
                        Trex700n
                        Trex700E FBL
                        Trex450pro
                        velocity50
                        JR 11X
                          Thanks for that, it worked!
                          Dji Phantom
