Hi all I've just put on a new DFC head on my 450pro Vbar.
What is strange is that I notice that the swash does not move down now when I hit TH. All my other heli's 550 vbar, mcpx, 130x and flybarred 450 have a swash movement downwards when I hit TH.
Have I setup something wrong this time around?
Also noticing a weird intermittent problem with my throttle. I'll try my best to explain. I start up in normal mode at full low stick I have no turning of the motor(as expected) But after a short hover when I land I go to full low stick and the motor is still turning a little under power. I then have to hit TH to completely cut the motor. When I deactivate TH the motor has no power at full low stick as normally expected. This behaviour will cycle. This seems really strange. Do I need to rebind at low stick again or do I need to recalibrate my ESC?
Surinder.
Surinder.
