Hi All.
I have been playing with the flip and roll rates on the Vbar. The problem I am having is with the servo ball links on the inside hole (standard Align alloy ones) With 11deg collective and 12 deg forward ele it bottoms out on the anti rotation bracket. Even with the collective only half way up say 5-6 deg it bottoms out with full forward Ele.
At the moment I am sure I am not using full forward ele and full collective at the same time but it just doesn’t seem right so keen to fix.
In the Vbar setup the cyclic and collective numbers are at 70 to get the 12 and 8 deg with the servo links on the shortest hole. If I moved out to the outside hole the link would clear the anti rotation bracket but the setup numbers would be say 55-60. Even 70 is out side there min suggested range of 80-100. What happens if you get too low a number in the setup?
To get 12 deg Ele I had to drop the DR on the Ele to 55. This made the flip rate really slow even with the Agility slider at 115. I increased at the field to 60 on the DR and the flip rate is ok but certainly not super fast. With the DR on 60 I assume now around 13-14 deg cyclic which seems like a lot.
Another option I was thinking of filling out the Anti rotation bar a little. Wouldn’t take much to get it to clear.
Or go back to the outside holes so everything clears but would be well outside the recommended setup numbers on the vbar.
Basically it is flying real nice. Just this small setup problem that is bugging me so keen to fix. Also no real range left to speed up the flip rate.
Havernt played with the Style or Gyro sliders yet. I assume they wont effect the flip rates just the way it feels. And it feels great.
Just remembered. I have zero on the Exp in the radio and 15 on the Vbar software. Maybe I go to zero in the software and see how that feels. Got the Bank switching setup now so might give that a go.
