Hello guys i need your help before put back my stock esc to my trex 550, i fancy to try governor mode with my 550 and installed icecc 100, since then it produce an annoying chirping sound i try to fiddle gov gain setting frm low high nothing change i try to changed the with 600mx 1220 kv still the same no changes any ideas that you may came accross this solve this chirping sound thanks ....Ken
Cant get rid of chirping noise
Have you got the correct PWM in the castle software for your motor ?sigpic
Do you have the Castle link, if so post the settings your using.Paul.
TDR Bavarian Demon 3SX, Pyro 750/56 comp Kosmik Cool 200, Savox,
I know the 600MX 510kv is a 10 pole motor. Not sure about yours thoughOriginally posted by aviatech22 View PostMy motor before is 600m1220 kv now i replaced that with 600 mx 1220 kv my setting 8 khz on pwm i try 12 khz chirping still exist and i put back again to 8khz correct me if this wrong i put 6 pole on the setting on this motor
SABGoblin 700 / V-Bar Blueline 5.3 Pro
Trex 500 FBL / Beast X
Futaba 8FG
Proud Owner of 2 EGS Awards
