Need help with tail kick problem
  • Need help with tail kick problem
    Been trying to sort the tail kick round on my 450 for a while now. Had the tail apart many times and it seems to be smooth and bind free. If I put the tail gyro gain any higher I get tail wag. The only suspect I can think of is the gain in the esc governor. I have as CC ICE 50 with the gain set at 15. The log is as follows:
    Also a video of the flight
    Garden Flying - YouTube (The log is from about 1:38 in the video)
    From what I can hear and see it sounds like the governor is way over compensating. The gain was set at the lowest standard setting. Should I drop this down lower? Help! :-)
    Thanks,
    Alastair
    Gaui R5 + 14S + Tribunus 200 + Scorpion 4530/540 + Bavarian Demon Axon
    Gaui X3L + Bavarian Demon 3SX
    Jeti DS-16, Citizen 625
    iMac + AccuRC =
    Member of East Fortune Aeromodellers
    Jeti Sensors and Apps: https://github.com/AlCormack
    15 should be good for the governor, works well on my 250-700's.
    Align's are notorious for tail wags caused by slop in the tail.
    Align have copied KDE and have produce the tail upgrade to their 450-700 heli's.
    I would recommend installing this upgrade with a carbon push rod.
    Sent from Android using Tapatalk.
      Thanks... I will do the upgrade when i can find the 450 one in a shop. The thing is that the tail holds well and does not wag. Just goes right if I punch the collective hard. The motor does sound like the rpm's are overshooting in the climb and not at end so that is why I thought the gain is too high.
      iMac + AccuRC =
        Upgrade done with V2 tail box and new slider (kept the stock push rod) and the tail is now totally locked in even with the 3GX on a full power climb. Really happy now!
        iMac + AccuRC =
