Uneven cyclic pitch
    Originally posted by daveman View Post
    I think I found the problem. I reset the model and the problem was fixed. The problem started when I used more than roughly 12 points of sub trim. To try and fix the porblem I have ordered some more servo arms to try and see if I can use less sub trim as my current values are around 30 on the closest to central spline. I will report back when I make progress. Thanks, David.
    TBH mate I find it difficult to believe that it was the subtrim that was causing your problems - subtrim does not effect how much servo throw you get, it only effects where the servo centre is and the endpoints move in unison with it. As I mentioned previously it was more likely due to having your endpoints at 60 and 100. Remember that these values would also of been cleared when you do a model reset.
    Velocity 50 (w/ Rossi R57) | Atom 500 | T Rex 450V2/Sport Hybrid
      Change one thing at a time - add the subtrim back in to get the arms level at zero degrees and then re-asses your total cyclic and collective pitch ranges.
      You may well be pretty close right now and not need new arms.
      JR Vibe Fifty fb (YS56)
