Throttle linkage setup.
  • Throttle linkage setup.
    Never mind.
    pop the servo end link off.
    close the throttle fully (including trim, to stop engine position), adjust end point on tx so it lines up and you could pop the link back on. Do the same at the other end with throttle open.
    Make sure its approx right angles at mid throttle.
    With the link on and throttle at each extreme check you can easily twist the link on the balls and it is not stalling the servo and going tight (servo should buzz if it is too).
    Pray you got the throttle right way round (on the bottom of the engine the throttle arm goes forward away from the back plate to open the throttle)
      Cheers Moyesboy.
      As you can probably tell I was at my wits end.
      I should probably have left my post active but with an ill child, no sleep and a linkage I can't seem to fathom I was overcome with a great sense of soditness.
      Thanks man.
      Duncan.
