550 3GX placement
  • 550 3GX placement
    Hi guys,
    Im about to start building my 550 V2 3GX, looking at the instructions the 3GX unit is placed upside down under the mounting plate (below the boom block) is this where everyone is putting it?
    I only ask because it looks to me that it would be impossible to get to the setup buttons and pots in that position.
    Tarot 450 Pro - (TP MG90's, 2215H, 40A Platinum, DS520/GA250, AR6200)
    Trex 550E V2 3GX - (CC BEC Pro) OMFG
    Blade mSR
    Spektrum DX8
    PowerLab 8
    Phoenix Sim
    I put mine up top as per 2nd placement location in the manual
    WWW.BETSOS.CO.UK
    Betting Made Easy
      Simples!
      Cheers, I did see the other plate position up top. Just the diagram shows it underneath, and photos of other 550's seem to have them underneath too. It does look better down there but would be a pita to set up.
      Blade mSR
      Spektrum DX8
      PowerLab 8
      Phoenix Sim
        put mine on a extension plate made from scrap carbon. cyano' ed below rudder servo, with wires going into body. This way i didnt have to change orientation settings and can plug in usb lead for updates and can access button and see light. No problems to date
          Not sure if this applies for the 550 but on my 450 I was told to try under the main shaft as it was less likely to take a hit in a crash and it was closer to the centre of rotation (although for roll pos 2 would seem better). Doing the setup was not too bad as the button is still accessible but was a pain to see the lights (ended up using a mirror)
          Gaui R5 + 14S + Tribunus 200 + Scorpion 4530/540 + Bavarian Demon Axon
          Gaui X3L + Bavarian Demon 3SX
          Jeti DS-16, Citizen 625
          iMac + AccuRC =
          Member of East Fortune Aeromodellers
          Jeti Sensors and Apps: https://github.com/AlCormack
            Hey.
            On the carbon plate fitted in the frames above the boom block, or i found mine was best on the lower carbon plate between the under carriage struts and behind the motor. Near enough directly under the mainshaft, for no other reason except it seemed to get less vibration there i felt.
            Ian Contessa
            Coolice Power Supplies
              Thanks guys,
              @ coolice, how do you get to the setup buttons etc. with it in there?
              It seems my posts take a while to show up, they have to be checked by the mod first , dont know how long that lasts?
              Blade mSR
              Spektrum DX8
              PowerLab 8
              Phoenix Sim
                Originally posted by CW. View Post
                Thanks guys,
                Hey buddy.
                Well there are 2 ways really;
                1. A soft, pointy screw driver. Or
                2. A very bendy little finger ;-) lol
                Either way needs a keen eye to see the led labels, but as you only really need to get to the button 2 times its not too bad.
                I then leave the dongle adaptor lead in place for pc connections.
                Ian Contessa
                  Cheers mate,
                  As said I haven't started the build yet, waiting till i can get my teeth into it properly!
                  Nice to have a plan though..
                  Blade mSR
                  Spektrum DX8
                  PowerLab 8
                  Phoenix Sim
                    Had mine mounted above the boom, easy to get to everything from there. But also due to the fact I was using sbus - i mount the receiver in the bottom position.
                    Jr forza 700 - one mean machine!lol
                    Logo 600sx v2- the big boy
                    Trex 550l- crazyness
                    Optim 80cp- Just amazing!
                      Hope this helps
                        Thanks for the pic sunny manku,
                        It does look easier to deal with in that position.
                        Blade mSR
                        Spektrum DX8
                        PowerLab 8
                        Phoenix Sim
                          put mine on the cabon plate with the 4 tabs on and fitted it at the back just above the base plate if i needed to ajust i could just fit a plastic screw driver in or removed one skid screw and pulled the plate out
                            Originally posted by sunny_manku1985 View Post
                            [ATTACH]36399[/ATTACH]
                            Hope this helps
                            where mine is also.
                            WWW.BETSOS.CO.UK
                            Betting Made Easy
                              Best place if you need to adjust the pots etc. in the bottom position you need to keep the USB lead in place, as you have no chance of getting it afterwards.
