hoping for a few pointers please, currently setting up my protos 500 have all the head setup but i cant get any movement from the 401?? red light is flashing slow on the unit,just doesent want to initialise,and not getting any movement from the servo,gone through my dx7 and cant see anything untoward and the only thing thats not conneced is the motor ! any ideas
No response from 401?
Had similar on a 450 with this. Slow flash indicates NO signal from the T/X to rudder so no servo response. I did a rebind and set up iaw the manual and it all came good. Fingers crossed.Trex 450 SEV2.
All other functions operating correctly ? 401 set to DS ? Gentle tug on signal leads at all rudder servo plugs and joins ? Plugging into thte aileron R/x output for a gyro response, this might indicate the quick connect isn't doing so. May I humbly suggest you get yourself a 750 ?Trex 450 SEV2.
You tried plugging the servo straight into the RX just to rule that bit out ?
NUMPTY !!Originally posted by supercaptaincrash View Postall sorted now thanks ! The lead wasnt 100% in the rx ! Cheers for the help
. No sweat kiddo, we've all done it, more than once if we're honest. Glad it's sorted, now get it set up and rip the a*se of it out there.
Trex 450 SEV2.
x 3
