HK250 gyro settings for servo
  • HK250 gyro settings for servo
    Hi
    I am in the process of building an HK250 helicopter.
    I am using an Assan GA250 gyro &
    a D922mg digital metal heli servo 1.8kg/ 12g/ 0.07sec.
    On setting up the gyro there are 4 types listed namely:-
    1520us/333Hz - 760us/560Hz - 1520us /250Hz & 960us/333Hz.
    I have searched the internet for the spec with no luck.
    Can anyone tell me the setting i should use with this servo?
    As i do not want to damage anything.
    Regards
    Barry
    From the HK user reviews for that servo...
    MD922 can have a maximum of 274Hz (less is OK) or minimum 3.65mSec (more is OK) Pulse rate/length.
    Probably be best if you read those reviews as the servo seems to be a little hit and miss.
    Proud owner of EGS x 4
    Owner of the mysteriously morphing signatur
    e
      D922mg servo spec
      Hi
      Thank you for your return messages much appreicated.
      Contacted Henge & they kindly gave me the settings for the D922mg servo for use wth the Assan GA250 gyro.
      They are 1520 us 250Hz.
      Hope this information will be of use to anyone using this setup.
      Regards
      Barry
