Kontronic Heli jive 101
  • Kontronic Heli jive 101
    Any one that using one got any tips?
    Had a setup this morning on a 700e with Scorpion 530Kv
    Ended up using mode 6 but very low numbers for Governor
    Is 35% to low?
    Cheers Paul
    Citizen #42
    I don't know the heli jive but 35% does seem rather low. It would suggest that if you cannot change the pinion the motor kv is too high. SO two choices; get a pinion with less teeth or get a motor with a lower kv.
    Member of Mk Heli Club
      I was getting 1800 at that %
      I don't want a high headspeed yet.
      More bits to buy before this thing flys
      Cheers Paul
      Citizen #42
        As an idication only I have seen a few 700 size models using a 450kv motor in order to use a reasonable size pinion for surface area coupling to the main gear and also to get the governor figure closer to 80% where the Jive runs better.
          Paul, there have been a few threads about both the LogoSE and the TDR running very low HS. I have seen figures as low as 32% with the Kontronic with no issues. It is mainly cheaper ESC's that have lower quality components that need the % higher, so they do less work to keep the temps down.
          31 minute flight on Logo 600 SE (with video now). - Page 1 - RunRyder RC Helicopter
          Henseleit TDR V-Bar x2
          SAB Goblin 700 V-Bar
          T-Rex 700e DFC V-Bar
          Synergy N7 V-Bar OS105 HZ-R
          Synergy E7se V-Bar
          Synergy N5c FBL V-Bar
          Gaui NX7 V-Bar YS91 Tareq SRX
          T-Rex 550 E FBL V-Bar
          Gaui NX4 V-Bar
            Jive/Jazz Programming - YouTube
            Found my low throttle to be 140 thanks to my last setup from Castle
            Thanks again guys
            Cheers Paul
            Citizen #42
              Here's a good video for programming mode 4 with auto bailout without the progdisk...
              John
              eAurora, Logo6003D
