beast x setup
  • beast x setup
    im helping a mate setup his beastx on his 700 which he bought second hand without servos. it was originally setted up and tested by the previous owner,
    anyway . qwe just have a question the cyclic servos arent moving the correct direction can we use the swash mix menu to make the servo go in the correct direction as we tried the three setups on menu "I " ??
    other than that i was told not to touch any servo trims or pitch curves in the tx when setting the beasty ,right?
    Long live the flybar.
    You shouldn't have the swash mix available, thats probably why it's not right. When you set the model up in the Tx set it for 1 servo. All mixing is done by the beast. Use a straight line curve to set it up in the first place and absolutely no trim
      ok, does it say that in the manual ,must have missed it
        I missed that bit too! Spent ages trying to get it working with the TX still on 3 servo CCPM! Changed to 1 and it all worked... And yes it is in the manual!!!
        700N 700E 550E
          It does, right at the start. Your better off starting with a new model memory and follow the instructions right from the off clear trims, no mixes etc
            Yes, Page 19, half way down. That is if it's Version 2.
            Not very clear for such an important item of setup. Lots of folks miss this.
            Reverse the 'Pitch' servo in the tranny to reverse the swash movement.
            As 'waveydavy' says, no trim setup in tranny, that includes no subtrim.
            You will no doubt go around the setup menus several times before you finally grasp the setup routine and get it correct..
            Good luck. It's nice when it is finally setup.
            TRex 500 FBL DFC VBar Pro Blueline, Standard Align Setup.
            TRex 500 Pro DFC 3GX, Standard Align Setup
            mCPX
            Phoenix
            Futaba 10C
              thanks my mate changed to 1 serv and .......ALL SORTED!
