Extra help needed
okay all. Im going to run the new 6203sb with a straight 7.4v as i like to try for the neat install/loose nose weight and get rid off the scott gray reg , going to run the new cgy 750 fbl unit , anyway i have the dual reg gryphon to use to step down my tail and throttle would this work? , the question is can i run a normal futaba switch harness/lipo as the reciever only takes the norm batt futaba plug, if not can the normal lipo futaba lead be enough to cope with the amps?would rather be able to use a switch though
other option is a heavy lead with a deans and a futaba plug fitted but cant find none anywhere
any thoughts much appreciated or may just stick with the scott gray
