Hi, I've recently finished building my first Trex 450 Sport Combo and everything looked fine. When I did a first test flight I found the cyclic controls were somewhat off ie giving forward elevator would cause the heli to go forward and left. This error was about 30 degrees and is visible on all cyclic controls. I decided to relevel the swash and I believe it made a little difference but hasn't fixed things. If I push forward and start to get some pace it does seem to correct itself but I'm wondering if this is normal. I also have a blade sr and can confirm it doesn't have this issue although the head design is different.
The other thing I'm finding is it appears far more twitchy than my sr hence I'm wondering if I have errors in my build or whether I simply need more practice.
To give you an idea of my level, I have been flying for about 6 months and have just got nose in hovering (with training gear back on for this).
I guess one option is to try to a club and have it checked over but I'm not sure of any in the Guildford area.
Any help would be appreciated.
