CYE Solid G set-up
  • CYE Solid G set-up
    I am in the process of swapping my 401 for a Solid G on my Trex 600e and i'm keeping the Futaba S9254 servo.
    It's my first encounter with a Solid G so it's all new to me!!
    I've got most of the settings done using the G-view, direction, model type etc, but there are a couple of points i'm unsure of and would like your input on before i go any further.
    First question,
    with the tail geometry set up for the 401 i have a pitch offset on the tail blades at neutral of around 8 degrees. The Youngblood instructions say to set up tail geometry while in "T/R neutral" and set the links to 90 degrees as per usual and also to set the tail blades centred at zero degrees.
    Do i need to reset the tail geometry from the 401's 8 degree offset to zero degree offset and will the Solid G automaticaly compensate for the lack of an offset?
    Second question,
    what servo type selection works best on the Solid G for the Futaba S9254 servo?
    At the moment i have it set for JR 8700G (which seems to work fine but tends to buzz a bit at idle) and it dosen't seem to like the available Futaba options which when selected send it off immediately to full deflection and stalling.
    Any help would be much appreciated.......and then i can go test it tomorrow
    Vic.
    VIC.
    JR DSX9
    TREX 600E
    Century GL450SE now an Align Airwolf
    Robbe schluter Jet ranger futura 111
    Planks.....Chris Foss Phase 6... Sebart Sebach 342 30E.......
    natures helicopters have the best HH gyros...... sigpic
    Set to 9253 servo setting
    If you have questions please feel free to contact me at climb out on 0208 66 88 335 and i will help you out
    If u r not crashing u r not flying hard enought
      Thanks Ade, i just tried your number.....................i'll call you tomorrow then!!
      VIC.
      JR DSX9
      TREX 600E
        are you nuts, the solid G feels like a horid gyro!
        Chris 'CHUNK' Newby
        ALIGN-TREX.CO.UK team pilot
        LYNX team pilot
        SPARTAN team pilot
        Dx18
          errmmmm....... Chris?........and yep, i am a bit of a nut .....only one way to decide if it feels horid..........i'll just have to try it for myself......
          VIC.
          JR DSX9
          TREX 600E
            there is tht,
            Chris 'CHUNK' Newby
            LYNX team pilot
            SPARTAN team pilot
            Dx18
              Solid G is a great gyro if set correctly, maybe a bit aggresive if not set correct. i know of a lot of pilots that still prefer the feel of the Solid G over the Mini G ...
              If anyone is having issues please feel free to contact us with any questions
              Hope this helps
                Many thanks to the guys at Climb out for their help and advice on the Solid G set-up ..........now i can go try it out
                VIC.
                JR DSX9
                TREX 600E
