hi all
ok so im not old lol but i am slowly recoving from an head illness that left me "slow" as my so nicly son would say ,in fact im relearning alot of things again.
been on the simulater for hours on hours relearning the basics etc as i don't really want to try repair my models (mostly custum ) so as an winter project i building an "trail" model to A: past time and B:learn to setup helicopters plus i like the building just much as flying...well i used to. so bare in mind im not flying it till given nod by trainer that im caple with the 300-450 class's again.
so the help i need is i ordered an HK599GT (i am aware of parts needing/recommend replacing).
i problem i have is the motor-esc-lipo side of things i would like to fit an "AX Typhoon 500H Heli Motor 1800kv" outrunner motor on 12 teeth pinion (is that the standard pinion ?)
its rated at 55amp (motor) but i can't or having trouble working out esc i need and what batterys , also Bec is esc witch powers the Rx right ?
thanks for reading hope you can help
also hope it all makes enough sense
gavin
gavin
x 3
