Trex 550e AR6200 connections
  • Trex 550e AR6200 connections
    I am at the point of connecting the electronics on my 550E.
    Which servo is supposed to be the AILE and which is supposed to be the PITCH ?
    Where does the pitch servo connect on the 6200, is it the gear connection.
    Also I have the GP780 gyro and I assume that the single yellow wire from the gyro goes onto the AUX1 connection.
    The manuals really don't show this and I really don't want to mess mess this up !!!
    Also any other tips that will help get this setup would be most appreciated.
    Ta very much !!
    RCHA - Guinness World Record Pilot 2011/12/13 Central Model Helicopter Club
    Some helis were damaged during the making of this signature.....
    Thro - Esc
    Rudd - three wires from gyro
    Gear - yellow from gyro
    Ele - ele servo
    Aile & pitch - either side cyclic servos (then use the reverse function on the DX6i to get them the right way)
    Eddie
    Velocity 90 FBL BeastX V3
    Trex 600 LE FBL BeastX V3
    Trex 500 EFL Pro BeastX V3
    Fusion 50 FBL
    VBar
    All powered by a DX8
      So let me just check.....
      AR6200 - Function
      THRO - Esc
      AILE - Left hand servo (aile)
      ELEV - Rear servo
      RUDD - Three wires from gyro
      GEAR - Yellow wire from gyro
      AUX1 - Right hand servo (pitch)
        Sorry.. Yes.. I was meant to say AUX1 instead of pitch
        Eddie
        Fusion 50 FBL
        VBar
          What you may find is that, depending on how your Tx is setup, your gyro may not initialise. I had this on a trex 600 and ar6200 just last night. Trick is, set the two gyro gains to 100 percent and zero percent. This is so gyro knows that there is a broad gap and allows it initialise.
          You will probably find you have to mess around with at least one channel, to reverse it.
          Trex 600E
          Blade MCP-X
          Dx6i/Chainlink UHF
            On my 450 I had 2 servo's reversed and a -time on swash mix to het everything moving right, its just playing around and working out what needs to go where
            Kev
              Ok cool ! I'll get wiring.
              Do you have any suggested settings for DX6i as a starting point?
                Yeah, set a new model and then work everything else from there
                Kev
                  I aint got a DX6 but a DX7 on a 500.. I have
                  Norm, Throttle 0, 50, 85, 100, 100
                  pitch -6, -3, 0, +6, +12
                  IU1, Throttle 85 flat
                  Pitch -12/+12
                  IU2 Thottle 100 flat
                  Pitch -12/+12
                  With the leccys, I've already mentioned using the reverse to get the all the sevo's moving the same direction and you might need to reverse the pitch if the swash isnt moving the correct way either.. its not as bad as you think!
                  Eddie
                  Fusion 50 FBL
                  VBar
                    Ok cheers for the help.
                    Any suggestions for the gyro settings for HH and rate modes.
                    Also any settings for swash mix?
                      Don't know for 550, but for my 450, swash mix was 65% in either direction, gyro gain depends a lot on gyro mate really
                      Kev
