boom turn
  • boom turn
    hi
    i dont know why my 700 tail boom keeps turning clockwise about 5-10 degrees every now and then . i tightened up everything and it keeps occuring . any of you guys come acroos these and how did you tackle it?
    thanks
    Ahhhh,
    Need to pin the boom
    Drill a hole on where the boom starts to enter the TT Hub and then put a screw in there
    You should have a Pin hole pre-drilled?
    I know when i purchased a new 600 TT Hub it came with a screw and a pre drilled hole.
    Take a look here:
    www.callumheli.co.uk
      Make sure you take the TT out before you drill it though!
      Unlike the previous owner of my 700! (mentioning no names, eh Mike )
      Ian
      Knight 3D
      Velocity 50
        I thought the 700 came with a pre drilled hole for a screw?
        I know my 600 did and my 550 does
        Goblin 700
          Mine has one wrap of tape around the front of the boom and that stops it.
          It normanly happens when oil from the fuel helps it slip, and also after time i think the plastic stretches at the boom clamp that then allows it to turn.
          James
          Sponsored by
          Align-Trex.co.uk
          Optifuel/optipower
          MKS servotech
            i see there is a pre drilled hole .but it still tilts a little even with the screw in the hole
              well i put in a slightly thicker screw in and it dosent turn anymore.kool
