set up problems
  • set up problems
    Hi, All
    My first post on here so a hello to all.
    I run a neon blaze, a rebadged walkera i understand!, my problem is that as soon as i plug in the heli battery the motor powers up even with the stick at zero, this is some thing i dont realy understand, perhapes the throttle curve is wrong. my transmitter is the stock that came with the heli, as i have played with the dip switches and the little knobs v1 and v2 i am now a bit confused on how to get things working again, can any one help by disscribing the correct set up, please remember i,m a bit of a begginner,
    Is the Stick at the bottom of its throw, or in the middle?
    x 3
      It sounds as if the dip switches have reversed the channel operation, so if you put the stick to full does it still do it. Or, your in idle up/stunt mode. What transmitter is it?
        thanks for very quick reply.
        my transmitter is a stock, cuk 2601 - 2.4ghz. i still have the issue if i have the stick at full or midway,
          UPdate
          Issue with the heli going into full throttle after plugging in was caused by a faulty speed controller, i replaced it and now all working ok,
