Have I fried my Rx??
  • Have I fried my Rx??
    hello folks
    I'd like a bit of help please....
    I have taken my Rx Spektrum, AR6100e off to tidy the wires better and when i have reconnected everything, no servos move
    The power led comes on but feinter than i remember and if i connect the bind plug it doesnt flash like it did before
    I have checked all connections and they look correct.
    Have I fried/bust it?
    Blade 130x
    Align Trex 150 DFC
    Align Trex 500
    Gaui 550 Hurricane
    HK 600 GT
    DJI Phantom 3 Advanced
    Phoenix sim
    I have a perfect record with helicopter flight...I have never left one up there!
    Is your battery fully charged are you fitting the binding plug on the battery pins and connecting the battery on any other
    Gaza07
    Trex 500esp 6s Beast-X V3
    Trex 600esp 12s Beast-X V3
    A few Multi Rotors
      tried 2 batteries... same thing
      bind plug is on the batt input, main battery powers BEC, from BEC lead plugs into thro on Rx
      when i plug the battery in, for a split scond LED is bright then drops to dim
      Blade 130x
      Align Trex 150 DFC
      Align Trex 500
      Gaui 550 Hurricane
      HK 600 GT
      Phoenix sim
        Sounds like some thing is pulling the power down are the servos connected if so try just the rx on its own
        Gaza07
        A few Multi Rotors
          check all plugs the right way up ie pos to pos not pos to neg. easy done i do it all the time lol
          Sponsored By
          Goblin 500-V bar T-rex700N with FLYBAR.
          http://www.lindensmfc.co.uk/
            checked all plugs, all connected ok
            removed them all except the power/throttle lead, bright led
            plugged everything back in, LED goes dim when i plug in LHS cyclic servo, goes bright when removed????
            but still no servos move
            Blade 130x
            Align Trex 150 DFC
            Align Trex 500
            Gaui 550 Hurricane
            HK 600 GT
            Phoenix sim
              Have you turned your transmitter on ?
              why are you using a BEC ? power is normally supllied via the ESC ?
                Get a picture up if poss
                x 3
                  rebind without this servo connected??
                    tried it....nothing
                    also tried re-binding with just:
                    ESC
                    ESC + gyro
                    ESC + every servo in turn
                    Everything connected
                    Everything except 'rogue' servo
                    still nothing, Rx led doesnt flash with bind plug fitted as it did before
                    ESC bleeps all times as usual but thats it, servos dont twitch, or move when sticks moved.
                    Blade 130x
                    Align Trex 150 DFC
                    Align Trex 500
                    Gaui 550 Hurricane
                    HK 600 GT
                    Phoenix sim
                      Does it smeel burnt out?
                      x 3
                        no smell
                        cant see any marks at all
                        Blade 130x
                        Align Trex 150 DFC
                        Align Trex 500
                        Gaui 550 Hurricane
                        HK 600 GT
                        Phoenix sim
                          I suspect that servo is broken, but maybe it's not the only broken part.
                          Disconnect everything. Try to re-bind using only Rx, battery and bind plug.
                          If the LED lights up, and goes dark when you turn off the Tx, chances are good that the Rx itself is OK.
                            Tried re-binding with Rx batery & bind plug only...LED doesnt flash when i try to re-bind
                            LED doesnt go dark when you turn off Tx, it stays bright
                            Seems like the Rx powers up but wont 'connect' to the Tx
                            Blade 130x
                            Align Trex 150 DFC
                            Align Trex 500
                            Gaui 550 Hurricane
                            HK 600 GT
                            Phoenix sim
                              Update folks....
                              borrowed an Rx, made new model memory, bound to Tx, all works as before
                              with the 'dodgy' Rx, connected a battery pack direct with bind plug on battery plug... B****r me it started flashing!! changed Tx to original model, Re-bound with Tx, all good...however, when battery removed and all plugs connected, back to square one, dim led nothing works
                              with borrowed Rx, all servos move as before I started messing
                              Blade 130x
                              Align Trex 150 DFC
                              Align Trex 500
                              Gaui 550 Hurricane
                              HK 600 GT
                              Phoenix sim
