Stupidly small allen key
  • Stupidly small allen key
    Anybody have an idea what the size of that stupidly tiny allen key that does up the flybar lumps/weights? I think I've lost mine and can't seem to find a suitable one in my kit of allen keys.
    Update:
    This is for the Trex450 Sport
    Regards
    Darryl
    Darryl
    Eflite Blade MSR
    Align Trex 450 Sport
    Spektrum DX6i
    BMFA Member
    What heli but prob a 1.5mm
      Some of the stuff on the 250 uses a 0.9mm IIRC.
      Martin
        Oops Trex450 Sport
        Darryl
        Eflite Blade MSR
        Spektrum DX6i
        BMFA Member
          http://www.trextuning.com/Trex%20450SE%20Manual.pdf
          It could be a 1mm looking at this if its that m3x3 grub screw.
            Guessing it's a 1.3mm hex then as I only have 1.5mm lying around.
            Darryl
            Eflite Blade MSR
            Spektrum DX6i
            BMFA Member
              It's the grub screw that sits in the Trex450 Sport flybar lump.
              Darryl
              Eflite Blade MSR
              Spektrum DX6i
              BMFA Member
                I think it is an 0.9mm, which is the size of the original 250 hex bolts before they moved to the later 1.3mm size. I am sure when I had a 450 Sport, I used the small 0.9mm allen driver that came with my 250.
                Steve
                Logo 500SE
                Forza 450
                  Think you're right as Ash used my allen key on his 250 at one of the Totton meets.
                  Darryl
                  Eflite Blade MSR
                  Spektrum DX6i
                  BMFA Member
                    Where can I get a 0.9mm hex wrench. I've tried looking at model stores but all of theirs seem to be 1.3/1.5mm minimum. I've seen a set at homebase that sells for £13 but I'd rather buy a decent set of RC tools.
                    Darryl
                    Eflite Blade MSR
                    Spektrum DX6i
                    BMFA Member
                      I might have to get a set of Rolson from Maplins for £5 and then get a set of RC tools for 1.3 upwards.
                      Darryl
                      Eflite Blade MSR
                      Spektrum DX6i
                      BMFA Member
                        Dunno what it's like tho: Fast Lad Performance
                        Martin
                          Tah Martin, will have to have a look at that one.
                          Darryl
                          Eflite Blade MSR
                          Spektrum DX6i
                          BMFA Member
                            If it's a 1.3mm you need, I got one from here.
                            phoenix items - Get great deals on trex, align items on eBay.co.uk Shops!
                            The heli hex sets I searched out all started at 1.5mm though I'm sure there's one out there starting lower.
                            I DID like the look of these though, real purdy ...
                            Koz
                            Total Relative noob
