Align Brushless motor question
  • Align Brushless motor question
    Hi all,
    Currently doing a full strip down on trex 450 for digital rebuild, on inspection the motor does not seem to be turning smoothly its like i need slight force to move it and it like notch moves hard to explain really also the shaft seems to move in and out 0.5 mm ish, im not sure how its supose to feel the motor as been on for its lifetime and been in alot of crashes never looked at it before ooops
    PS if its no good can anyone recommend a motor a can buy to replace Align Brushless motor 430L 3550KV cheers
    Lee
    T-REX 450 SE (CDE)
    Spektrum DX7 Transmitter
    Align GP780 Head Lock Gyro
    AR7000 Dual Link Reciever
    Turnigy 3S 30C 2200 Mah 11.1v LIPO
    Savox Digital servos SH0257
    Tail Servo Align DS520
    Its Only Time The Ground Will Get You
    The motor has magnetic plates & coils so when you turn the motor you get a reaction from the magnetic field bit like trying to put two magnets together so yes its normal on brushless motors & the free play is about right.
    • Flickr Through My Pictures.
      Hi tourerjim,
      Thanks for the info that makes sence was slightly worried for a bit
      Lee
      T-REX 450 SE (CDE)
