hi all
im rebuilding an messed up art tech hughes 300 ( i know not the best but it do till i lernt to fly)
basicly the gyro rx and tx are all diffent than the box or manual and would like some help on basic connections setups if you don't mind
current set up is
6 channel rx
ch1-aile =connected to servo controling swach plate side tilt
ch2-elev=connectd to servo controlling swach plate front/back tilt
ch3-thro-gos to esc
ch4-rudder= gos to gyro 3pin lead
ch5-not connected
ch6-aux1-connected to servo under main shart going up the middle of it.
gyro head lock and normal
3pin lead to ch4 of rx
1pin extra white not connected
out put to tail servo
also the box say 18amp esc and motor b20/10t but the esc on heli is 30amp and well the motor the frames needs mods to fit at 90oc to the main gear.
will the up rated motor be ok in this model with belt tail drive ??
also the seller had an no returns statement and ebay/paypal not much help.oh while im at it the gyro is now an v3 art tech not v2 as on box and tx and rx is now art tech 2.4 GHZ not 35MHZ
atm the heli is striped down to bits only bits still togeather is the eletrics so once i find out current motor and eletrics be/are ok i go ahead with rebuild and post new topic on pitch degrees
thank you for taking time to read and hope very much you can help an noob
gavin
sorry for the long post but i wanted to put in as much detials as possable1
current set up is
6 channel rx
ch3-thro-gos to esc
ch5-not connected
.thank you for taking time to read and hope very much you can help an noob
gavin
