Hi Guys,
Being a new boy I am having some problems getting my MiniTitan E325 stable enough to fly properly and one thing I notice that could be a cause is the following:
The tail rotor pitch control on my machine is very asymmetrical. Looking from the rear of the helicopter, full right on the pitch control slider gives 15 degree pitch angle in the correct direction to counter the main blade torque reaction i.e. to rotate the helicopter clockwise. Full left on the pitch control slider gives 45 degree pitch in the direction to reinforce the main blade reaction. Centre (rest) position therefore gives 15 degree pitch in the wrong direction to counter the torque reaction and, without a large control input, to spin violently anticlockwise. To get zero pitch requires the slider to be at 75% of full right leaving only 25% of further movement right. I do not know how much pitch angle is required to just counter the torque reaction and hold the heading steady but say it is 10 degrees, this leaves only 5 degrees further movement for control in this direction but 95% in the other direction! This seems wrong to me and I suspect could be the reason why HH mode does not function properly on my model. I would have thought that, at least, the centre position should give zero pitch and preferably 5 – 10 degrees in the direction to counter the torque reaction and not to aid it! The only way I can see to achieve this is to reverse the direction of rotation of the tail rotor opposite to what the manual shows. Has anyone else found this or have I got something else set up incorrectly? Any advice would be gratefully appreciated.
