Whats your Trex 450 settings ?
  • Whats your Trex 450 settings ?
    Hi all
    If you use a dx6i or similar with your TREX 450, what are all the setting you have set into your transmitter.
    These are the setting i need :
    Throttle Curve - Normal =
    Pitch Curve - Normal =
    Revo Mix - Normal =
    D/R&EXPO - AILE - ELEV - RUDD- ? =
    Swash Mix - AILE - ELEV - PITCH ? =
    Setup List
    Throttle Cut - INH-ACT ?
    D/R COMBI - INH - AILE - ELEV - RUDD - FM
    Any other info would be much appretiated
    Thanks everyone.
    P.s. No offence to anyone, but if you havnt got a direct answer to my question can you please not reply, i need YOUR settings, please do not refer me to another thread or forum with the answers, unless they give me all the answers i need.
    ____________________
    Sam
    My Website - http://samsmithsphotography.webs.com/
    167749
    If you want these settings you are asking for quite a bit of data entry by the guys here. To help them to help you, why not put together a template that they can populate, i.e.:
    Throttle Curve:
    Pitch Curve:
    Swash Mix:
    etc:
    etc:
    By doing this they will know precisely what you need and will not waste their time telling you stuff you already know.
    You might find you'll get more answers. This will not necessarily be a good thing tho - you will get as many variations as you get answers. Everyone has there own way of setting up, none are "right", none are "wrong" but all of them work for the person using them, none of whom are you.
    Martin
      Would be better watching the finless videos on Helifreak
      x 3
        On my DX7 and 450SEv2 I have:
        Throttle Curve - Normal = 0, I, 90, I, 90
        Pitch Curve - Normal = 40, I, 50, I, 91 (this gives me -2, 0, +10 degrees)
        Revo Mix - Normal = Up = 0, Dn = 0
        D/R&EXPO - AILE - ELEV - RUDD- ? = Ail = +20, Elev = +20, Rudd = +10
        Swash Mix - AILE - ELEV - PITCH ? = +60, -60, -60
        Can't help with the Setup list as things are different on the DX7.
        I agree with Paul tho. Watch the HeliFreak videos as, by putting my settings, or anyone else's, into your radio may end in tears.
        Martin
          As Mart has said be careful using any settings, results may difer, failing that watch finless.
          Though your saying you want settings only, the best advice can be taken from bob:
          http://www.helifreak.com/showthread.php?t=11373
          On the dx6i flying a 450 pro I have:
          Throttle Curve - Normal = 0, 42, 90, 90, 90
          Pitch Curve - Normal = these give me -2 and +9 36.5, 43.5, 50, 75, 100
          Revo Mix - Normal = no revo mix
          Aile =85% +12
          Elev =85% INH
          Rudd =85% +25
          Aile = -60%
          Elev = -60%
          Pitch = +55
          Setup List
          Throttle Cut - ACT (never used it but its active)
          For D/R combi ive set it to FM because then when I switch it I get idle up and 100% across for D/R
            Throttle Curve - Normal = 0, 60, 75, 90, 100
            Pitch Curve - Normal 0-25-50-75-100
            Aile =100% INH
            Elev =100% INH
            Rudd =100% INH
            Swash Mix - AILE - ELEV - PITCH ? = depends i have to change these each time i do the pitch adjustment
            Aile = -85%
            Elev = +60%
            Pitch = -55%
              Settings for TREX450 SE V2
              Throttle Curve - Normal = 0,70,70,70,70 (running governor on CC Phoenix 35)
              Pitch Curve - Normal = 40,43,50,75,100
              Revo Mix - Normal = 0 (no need to use this it was used prior to HH gyros)
              D/R&EXPO -
              AILE - 100% +8%
              ELEV - 100% +8%
              RUDD - 100% INH
              Swash Mix -
              AILE - +68%
              ELEV - +68%
              PITCH - -75%
              Swash values give me +- 11 degrees pitch when using 0,25,50,75,90 pitch curve and about 6-7 degrees pitch on AILE and ELEV
              Setup List
              Throttle Cut - INH
              D/R COMBI - ELEV
              Also set rudder end points (TRAVEL ADJUST) at 90 in both directions to reduce piro rate slightly
              Velocity 50 (w/ Rossi R57) | Atom 500 | T Rex 450V2/Sport Hybrid
                I dont understand when you say :
                Because on my DX6i, when im on the thro and pitch curve scrren it comes up with:
                Pos - 3
                50.00
                And you can change these, but you cant change it to make it like the thro and pitch curves you mentioned.
                Am i missing something here
                Sam
                167749
                  Pos - 3
                  50.00
                  He is saying that his pitch curve is set to 36.5, 43.5, 50, 75, 100 (for POS - L, 2, 3,4, H) in normal mode and this gives him a pitch range of -2 degrees to +9 degrees. These values are dependant on the values he has set on his swash mix for pitch.
                  He has only got +9 degrees at 100% pitch which is an indication that his swash mix for pitch is set fairly low as I believe you can get about 13 degrees of pitch out of the 450PRO
                    just to make your life simple go through 3 of these vids .u should be ok then...
                    [ame=http://www.youtube.com/watch?v=qe2WhjLqdGs&feature=related]YouTube - Basic Collective Pitch setup using a DX6i part 1[/ame]
