using wd40 to lub
  • using wd40 to lub
    hi i was watching a vid on you tube yesterday where bert krammer i think was using the wd40 on the tail for lub.
    seems like a good idea, why didnt i think of it first.
    Spray it anywhere near bearings and it will wash the grease out. Then you will have bigger problems than the WD40 was supposed to solve.
    Member of Mk Heli Club
      Agreed, for bearings I use lithium grease spray and then work it in by rubbing the bearings and rotating the bearings. For the belt I use silicon spray.
      Both can be bought from B&Q.
      Darryl
      Eflite Blade MSR
      Align Trex 450 Sport
      Spektrum DX6i
      BMFA Member
        Darryl what silicon spray do you use? I was supposed to use some on my 500 torque tube but didn't have any....so didn't use any!! Hopefully it will be ok tho??
        Trex 500ESP - Scorpion motor, CC ice 75 esc. Spartan Quark gyro, Std Align servos
        Knight Sport - Spartan/BLS251, Hyper 50, 3050's on cyclic, 3D mixer arms
        Outrage Fusion 50 - Viper 700kv, 14t, Align servos, Spartan, 8s, Hobbywing 100HV. Maidened - Love it, set up to fly really smooth :-)
        Gootch 450SEv2 built and flown, very nice heli :-)
        MCPX BL
        MPX Twinstar (In bits!!)
        DX8/Futaba T9CP
        Phoenix
          Just a large can the size of WD40 that you can purchase from B&Q for about £5 I think. They do lithium grease aswell. Both of them have the red tube applicators.
          Darryl
          Eflite Blade MSR
          Spektrum DX6i
          BMFA Member
            i use Vaseline on shafts as it does not interfere with bearings. :-)
            Mike
            www.RC-Scotland.com
            TZ Frenzy .53 Red Line
            T-Rex 600 .52 ASP
            T-Rex 600 .80 ASP 4ST
              Hi Guys
              Thanks for the info. Have a 3DX-500 with an annoying squeak I am trying to eradicate. Will try that silicon spray.
              Puzzled about greasing the bearings. Aren't they supposed to be shielded, and lubricated for life?
              Got a tube of lithium grease, and silicon grease, which would be better?
              Jeff
              P.S. Can't remember where I got the Lithium grease from, but the Silicone came, of all places, from Amazon.
              Comes in tube big enough for about a thousand bearings. Marketed as Servisol, only cost about a fiver, with free delivery.
                hey guys ive been advised by pros to buy the general household oil from asda to use on my 450 pro! like the ones you use on sewing machines so even cheaper!great
                  WD40 is NOT a lubricant !
                  Janek
                    WD stands for Water Dispersant
                    Janek
