450 pro
  • 450 pro
    hi guys
    Just wanna know do i have to put a washer im between the screw and nut to hold the blades as there is a small gap in between i noticed.
    Or
    Do i need to keep screwing till its just tight thnkx
    What does the build manual say? Whatever that says, do it. Are you talking about the bolts that hold the blades into the grips or the feathering shaft bolts that hold the grips onto the feathering shaft?
    Martin
      For installing the blades into the grips?
      Shouldn't have to use any spacers. What blades?
      Try tightening them up but it shouldn't take much force, you want the blades quite tight in the grips.
        oh yeah it worked i just had to tighten it duh!
