hi guys im building my copter x and im tring to bind up with the ar6200 and when i connect the lipo to the esc the lights dont flash.this is my first build...and im sure i have gotten all the wires mixed up and i i dont know which side is pos and neg and which wire goes where...i have build the servo and gyro etc already just the wires are all mized up on the rx
rx wiring
Firstly, have you got the bind plug in the correct place, then power up the rx the lights should flash, you then turn on the radio whilst holding in the bind button on the radio. I personally bind all my receivers first before connecting them to the heli so i know there are no faults before I startRob
TDR (in progress)
SAB Goblin 700
Vibe 90SG Vibe 500E
Kalt Baron30
hi there guys thanks all i binded it up all controls work now to connect it all upLast edited by 3Dheliflyer; 24-03-2010, 03:57 PM.
that set up is totaly wrong dude your left stick is down and your servo arms are level!!! you really need to do some homework first
your also messing with it with the motor connected thats bad!!!
guyes is this correct wiring,looking at heli in front of me using ar6200.
the left servo goes into aileron
the right servo goes in to aux 1
the servo that is in the middle meaning after the 2 servo but close to them goes to elev.
gyro is in the rudder and gear esc is the throttle,
x 3
