Csm revlock Head speed
  • Csm revlock Head speed
    Hi All
    I'm in the middle of fitting a revlock 10 and would like to know the headspeed for a knight 3d please if anyone can help.
    Should i also use the governor facility in my PCM9Xii or should i use just the gear channel and adjust the travel limit to get the required head speed.
    I know A is for one speed (normal ?) and the B for (Idle up ?) i think.
    If i use the governor facility i can apparently have seperate speeds controlled by the flight mode switch,am i understanding this right?
    Cheers Gaz.
    Life's easy it's just the choice's that's hard
    If you're using a 9Xii then plug it in to Aux 2 you can then use the 3 position switch front top left to give you 2 governor speeds and off, works well for me.
    Steve H
