50 3d,pcm9iii and spektrum AR9000 Help Please
  • 50 3d,pcm9iii and spektrum AR9000 Help Please
    Anyone set this config before,
    Set swash type to 3s 120,plugged in channels,pitch to Aux1 is this correct?
    Problem i have (if it is one) pitch and throttle seems to move swash to the left/right and the aileron seems to move swash up and down.
    Tried swapping servo leads over in reciever but still has the same effect,am i missing something simple.
    Gary
    Life's easy it's just the choice's that's hard
    On your swash mix, experiment with changing one of the values to a negative value to swap the direction of travel, that should sort you out
    So it is something like
    AILE 60%
    ELEV 60%
    PIT -60%
    for example
    Nick
    Henseleit TDR 2011 VBar 5.2, Avant Aurora, 700N BeastX, 500 BeastX
    Member of Byley MFC & South Cheshire HeliAddicts (www.southcheshire.rcheliaddict.co.uk)
      Same setup and the above is correct for mine
        what you should be aiming for is the swash going up and down the right way .. plug the leads in the Rx .. dont know the squence for a spekky as i run futaba .. move the throttle up and down .. if you have one servo going the wrong way to the rest then reverse that servo ... then when you have all 3 servos going up and down then you can start and set the swash menu .. and whats good for one person is not sometimes good for another as diff servos go diff ways .. right if the swash is going the wrong way then change it in the swash menu so its the opposite of what it is originally .. then you can set the others up ....hope this helps ..
        Knight 3D
          Have re-done everything but still none the wiser,move the throttle and all servos move,swash moves up+down,left+right,forward and back,
          move elevator swash tilts forward and back,
          move aileron and the swash moves up and down main spindle
          everything seems to move in the correct directions to inputs so dont think any need reversing.
          I take it i am right in needing to set the swash setting to 3s 120 and not leave in normal 1s
            yeh its wants to be 120 3 servos doing all the movements ....
            Knight 3D
              left/right servos need to be in 2 (aileron) and 6 (pitch/aux1), centre servo in 3 (elevator)
              once you have that right, move the pitch up and down then reverse any servo that isnt moving in the right direction for the pitch.
              once you have that then, move the aileron and elevator, if you find their direction is wrong (eg stick forward swash goes back) then change the swash mix value for the elevator from +60 to -60
              hope this helps,
              Ade
              www.accurc.com
              adrian@accurc.com
              This is an apple free zone
                Finally got it sorted, one of the servo's required reversing,ch2,pitch -60%, everything ow seems to move in the right directions.
                Just one more question for now,(bloody pain i know) but with all sticks centered should the swash be totally level as a starting point,going to bring home a digital venier from work to check all rod lengths are the same,
                Thanks for the input
