Hi guys hope you all had a great xmass.
During my 2 week holiday I've had plenty of time to think about how I actualy set up my machines & was just wondering if I'm doing anything wrong or not.
I set every machine up the same from my electric 450 & 500 right through to my 90 airskipper.
Normal flight mode
I set normal flight mode on throttle to a straight line of 0 25 50 75 100% throttle.
The pitch curve for normal mode is set at plus & minus 10 degrees & the hover point is just over mid stick position in both positive & negative (inverted hovering).
I use normal mode for spooling up on the IC stuff & then just before take off flick straight into idle up one.
Every landing is done by using the hold switch a few feet above the ground & a small auto back to terrafirma.
Idle up 1
Idle up 1 & 2 is set exactly the same on the pitch curve but I tend to set a V curve for the throttle which would normaly be 100 75 50 75 100%
but tailor this to head speed with the governor turned off.
Idle up 2
Funny but I never have found a good reason to use idle up 2
So I just set this mode up exactly as idle up 1.
I just use this mode as a trim change mode for my 450 & 500 which use different weight flight packs & using idle 2 in this way I can get the hover spot on with either set of packs.
Throttle hold
Now this i where I am strugggling big time especialy in auto's.
What pitch curve is best to use for hold?
I set mine at plus & minus 10, the same as I do all other modes.
The problem I have with this is that every time I've had a flame out on the 600 it's ended in a bin bag.
You see I always panick, flick the hold pull full negative & then before I have realised what I have done Ive stalled the head & it drops to the floor like a sack of the proverbial so this is an area I need to improove upon.
Aileron & Elevator
I max these out at full positive & negative pitch & make sure nothing binds at the extremes of pitch.
Rudder
I dont like a powerfull tail so I set the rudder up so that a piro takes maybe 2 to 3 seconds at full stick.
Dual rates
I dont use dual rates at all.
Exponential
I'm a fairly nervous person & my hands shake a little even on a good day so I tend to use alot of exponential as much as 40 % sometimes to help smooth out my nerves.
I think thats about it & would love to hear your cmments on how you set up your helis & if you feel I might benefit doing something a little different please feel free to post as I'm desperate to improve my flying & I feel maybe my setup maybe hindering my progress.
Heres Wishing you all a happy 2009.
I've heard it's gonna be the warmest yet according to some study group. lets hope so
Regards Martin
Normal flight mode
Idle up 1
Idle up 2
Throttle hold
Aileron & Elevator
Rudder
Dual rates
Exponential
Regards Martin
