Spektrum AR7000 Rx Help
  • Spektrum AR7000 Rx Help
    Hi All,
    got a slight problem.. Not sure what some of the connectors go into,
    but i think ive got them all correct,
    ive managed to get teh swash plate to move accordingly to stick controls, but the Engine Servo rod moves, also when i increase the throttle it messes up, so im not sure,
    at the moment, here is whats connected
    Throttle: Connected to Servo that moves the Collective Tray
    GEAR: Is the other Gyro Cable
    Rudd: is Gyro Cable that connects to Ruder
    Ailrone: Connected to Servo that makes the swash goes left or right
    Elevator: connected to the servo that makes the swash tilt forward and backwards
    AUX1: is connected to the engine servo.
    So its just realling knowing the correct servo that goes in the correct Port of the RX
    Forgot to mention:
    when i increase the throttle, every other servo moves apart from the engine servo and rudder, i have also set the swashplate in the Tx to 120 CCPM
    www.callumheli.co.uk
    Throttle and Aux1 need to be swapped over Callum
    SPARTANRC Team pilot
      Swap the throttle & Aux connectors and you'll be good to go
      Ian
      Knight 3D
      Velocity 50
        Right ive done that
        also when i increase the throttle, every other servo moves apart from the engine servo and rudder, i have also set the swashplate in the Tx to 120 CCPM
          That's right.
          All 3 swash servos are used for collective pitch changes, and you want the throttle to correspond to the pitch changes too.
          Ian
          Knight 3D
          Velocity 50
            Hang on a minute... Is this going in a Raptor??
            If so, you don't want it in 120 CCPM mode.
            Ian
            Knight 3D
            Velocity 50
              But they all wrong, the aileron moves aswell only when i increase the pitch and that shouldn't happen
                But it has a 120 Swash Plate,
                  Callum, I'm assuming this is for a Raptor? in which case it should not be set to CCPM in the TX
                    It should be 1 Servo, see page 75 of the DX7 manual
                      Im totally confused? I have a Raptor 30v2.
                      ile try 1 servo thingy
                        The 120 setting is for a Eccpm model where 3 servos all push/pull the swash up or down together. Your Raptor uses 1 servo for pitch, 1 for aileron, 1 for elevator. Set TX to Normal 1servo.
                        Ian
                        Knight 3D
                        Velocity 50
                          Your totally correct...
                          1 Servo (NORM)
                          Thanks so much!
                          the elevator is a bit low so ile try and adjust that!
                          but i thaught with a 120 swash plate that is CCPM?
                          Oh well learnt something now
                            We will soon knock you into shape..callum..LOL..Is that better now?
                              The Raptor achievies it by Mechanical Mixing.. 1 servo for the pitch function. When people talk about CCPM or more correctly eCCPM the mixing is done electronically in the Tx
