Wooden blades
  • Wooden blades
    I need to recover some wooden blades of of an old Kalt space baron what do i need.
    Raptor 30v2
    Skya 500 x 2 one to be Scale Bo 105
    Copter X450 x 2
    Trex 250 x 2
    Mcpx
    Raven wing.
    Suhkoi
    Anx Floater
    Radjet 800
    DX7
    Phoenix v4
    Proud to be member of SCHA
    Log Cabin for Hire in Snowdon.
    http://www.youtube.com/user/streetlu...s?feature=mhee
    Unless you are 100% sure about the condition of these 'old' blades, I would bin 'em and buy some new ones mate.
    Ian
    Knight 3D
    Velocity 50
      You can not get these anymore.
      Raptor 30v2
      Copter X450 x 2
      Trex 250 x 2
      Mcpx
      Raven wing.
      Suhkoi
      Anx Floater
      Radjet 800
      DX7
      Phoenix v4
        Won't a standard set of 30 or 50 size woodies do the job?
        Or is there something special about the blades in question?
        | 3D Championship
          Quick UK do Blade covering heatshrink...
          or at least they used to. Have a look on their website.
          Andy
          sigpicX2
            They are odd size 8mm root and only 520mm its a pain in the bum.
            Raptor 30v2
            Copter X450 x 2
            Trex 250 x 2
            Mcpx
            Raven wing.
            Suhkoi
            Anx Floater
            Radjet 800
            DX7
            Phoenix v4
              You can get Gaui wood blades that are 500mm but I'm not sure what thickness the root is and I think it's the same size as the standard 550mm woodies.
              My Kalt gasser uses 680mm blades and a massive 18mm thick root at the blade grips but fitting blades with a 14mm root is no biggy as you can just use some washers.
                Check the blades carefully for any sign of splintering or cracking, especially around the root area. Damage to the balsa trailing edge can be repaired, but its imperative that the hardwood "spar" is perfect - especially around the bolt area.
                Aside from heatshrink tube - which is the easiest to apply - you can also use any Solarfilm type material. If you want something a bit weightier, use Fablon - though this can be tricky to apply cleanly.
                Speaking as an old fart who has been flying helis since Pontius was a pilot (well, over 30 years anyway!), my early machines all used hand carved blades, as I couldn't buy any the right size for my original plan built machine! I don't claim to be the world's greatest wood worker, but I did eventually manage to make sets good enough to fly reasonably well. Fablon gave the most durable finish, but was also the most fiddly to apply!
                Remember to balance them carefully when you've done. You are unlikely to get a perfect balance without adding some extra covering to one blade!
                Best of luck!
                  wow hand carved blades!!! makes you realise just how easy we have it now. so there's your answer chris get that whitling stick out and get busy!
                  oh and btw hobby hanger stock the heat shrink covering when you've got then done
                    Chris ive got a pair of these blades brand new unused, need covering yours for free if you pay for postage, ill double check the length when i get home (10:15pm) but they are yours if you want them
                      Thanks Kev I will double check on the size if there space baron should be right.
                      Raptor 30v2
                      Copter X450 x 2
                      Trex 250 x 2
                      Mcpx
                      Raven wing.
                      Suhkoi
                      Anx Floater
                      Radjet 800
                      DX7
                      Phoenix v4
                        If I get some which are longer and with the right root can i cut them down and balance them.
                        Raptor 30v2
                        Copter X450 x 2
                        Trex 250 x 2
                        Mcpx
                        Raven wing.
                        Suhkoi
                        Anx Floater
                        Radjet 800
                        DX7
                        Phoenix v4
                          you can but i wouldnt recommend it
