Can any one help please, new flyer can now hover ok but just starting to fly around, have got got 10c manual and Marie Cross book but both are confusing on setting idle up, been into condition to change switch and changed numbers on throttle curve screen, using three position switch E wanted forward (I think they call it up) as normal curve but only seem to be able to set this as idle up 1 on throttle curve screen.
Futaba 10CG setting Idle Up
10C radio menu system is different to my futaba's, but you can change the switch positions in the condition menu. With throttle and pitch curve screens, I think you need to access these through the advanced menu to edit all conditions. Normally the screen will show the condition in brackets ie. (1), (2), (N), (H) etc which is what the radio is set to with the switches. The condition that you are editing is shown with out the brackets. You just need to get the cursor to the condition symbol which is not in brackets and change it to the condition that you want to edit.Graham
Titan X50E Bavarian Demon 3SX
Trex 500L Bavarian Demon 3SX
Trex 450SE Flybar
Futaba 14SG
