blade 400, position servo arms after stripped gear
  • blade 400, position servo arms after stripped gear
    Hi,
    I need some advice on setting the position of the servo arms on my blade 400 3d after my first crash. I discovered after the crash that two of the 3 main servos had stripped gears, after fixing the servos it became apparrent that I have no idea how to reattach the servo arms (positioning). Do I just power on the bird and pop everthing on at 90 degrees. Or is there a more precise way of doing this.
    Chris
    Make sure the sticks are all set at mid position, then put the arms at 90' to the servos.
    works for me.
