Trex 550 / Gobin 570 bogging on rainbows
  • Trex 550 / Gobin 570 bogging on rainbows
    I tried my first rainbows tonight and they weren't too awful, but I did notice that the helis were bogging when changing direction. The goblin wasn't too bad but the trex was.
    Is this just down to bad technique or are there things which I can change in the setup to help?
    Oxy 2 - Spartan VX1n
    Trex 700XN - Spartan VX1n
    Trex 700N DTS - Spartan VX1n
    Logo 690SX - Spartan VX1e
    780L Top - VBar Neo
    2 x 700L Top - Spartan VX1n
    Logo 550SX - Spartan VX1n
    Jeti DS14 BK edition
    DX9
    Pheonix R/C
    AccuRC
    neXt
    Too much pitch & not enough headspeed? I run +-13 degrees on the goblin with no issues and power in reserve. Try increasing the headspeed a little at a time if your pitch isn't overbearing. Rainbows are long and smoothe and a precursor to tic tocs you shouldn't be bogging the motor really. If it's not either of these look to your flight pack? What is your setup on the Goblin?
    [/SIGPIC]Goblin 700 vbar blueline, spektrum Hv servos|Goblin 570 Red/Yellow, mini vbar pro, BK's|Goblin 500 red, mini vbar pro, scorpion 4020 1100kv, jive 100+,BK's |Goblin 380, xnova 2820, mini vbar, yge 90, quick connect|Trex 450 pro 7200bx & RJX fbl head|130x|ncpx|DX9| BMFA Member|
      I think im already running the max HS according to the CC gov any way.
      Im running
      +-12
      HS 2382rpm IU2 CC Gov @ 95.8%
      CC Edge 120 HV
      Xnova 4025 1120
      VX1n (Heli Style 3d all defaults)
      Haiyins 6s 5000mah 20 - 30c
      23T pulley / pinion
      CC Setup
      Gov Gain 25 (Medium)
      Spool up rate 8 (High)
      Headspeed change rate 8 (High)
      Motor Timing 3
      PWM Rate 12khz
      According to the CC log my average HS is 2608 and the max is 2644
      Average amps are 51 max is 103
      780L Top - VBar Neo
      DX9
      Pheonix R/C
      AccuRC
      neXt
        How low does the head speed go during the moves?
        Spektrum IX12
        Blade Inductrix
        T-Rex 150X
        T-Rex 450L, Heli Option Turn-buckles, carbon push rod, 6s, Stock Electrics, Giant Power Lipos
        Goblin 380 Kyle Stacy, 360mm, 6s, AR7210BX, Align 430m/525m @ 6.0v, Castle Talon 90, Scorpion 3020-1000, Optipower 2700 30c
        Goblin 570 Carbon Red, Stretched to 600mm, Blackline 3D Blades, 12s, BD 3SX, Align 800/850 HV servos @ 8.0v Castle 120 Phoenix Edge HV, Scorpion, Thunderpower G8s
        T-Rex 800e Pro DFC, Hobbywing 200A, 760x Head, BeastX
          2550 ish I think. Looking at the graph from the log.
          If my headspeed is set to 2382 how comes its averaging 2608?
          780L Top - VBar Neo
          DX9
          Pheonix R/C
          AccuRC
          neXt
            im not sure what qualifies as 'bogging' but i dont think 50 drop from average is too bad?
            er, i have no idea why the rpm is over reading though!
            Spektrum IX12
            Blade Inductrix
            T-Rex 150X
              Tbf at the time i was going by the sound it was making and the lack of power feeling. Probably should have looked at the log first!
              780L Top - VBar Neo
              DX9
              Pheonix R/C
              AccuRC
              neXt
                i understand, there will always be a slight noise change on reversals etc especially on a reactive governor, maybe proactive ones handle it better im not sure.
                either way go 12s
                Spektrum IX12
                Blade Inductrix
                T-Rex 150X
                  either way go 12s
                  I already have the investment in the batteries for 6s maybe next season I will consider 12.
                  Its quite a big noise change on the trex
                  780L Top - VBar Neo
                  DX9
                  Pheonix R/C
                  AccuRC
                  neXt
                    It could be, they definitely struggle to get back the other way, more so on the trex. I was wondering if it was me but as its a lot worse on one heli than the other im not too sure.
                    780L Top - VBar Neo
                    DX9
                    Pheonix R/C
                    AccuRC
                    neXt
