Walkera Master CP Binding
  • Walkera Master CP Binding
    Hi Guys,
    I am having binding issues with my Master CP and Devo 7 transmitter. As I understand (and yes I am new to this hence the question) when the transmitter and receiver bind correctly the red light on the heli should be constant. However on mine it remains flashing and I don't appear to have full control of the heli. Any help on the issue would be greatly appreciated.
    Walkera?
      Originally posted by Mike Sanders View Post
      Walkera?
      Sorry fat fingers and auto correct when typing. Yes meant Walkera 😜
        Usually with walkera transmitters have a 10 sec bind windows, so if you're doing a random Id bind you've got to be quick plugging in your battery after you've switched your transmitter on. A fast flash on the receiver means it's looking to bind, A slow flash means you have a fixed Id and will have to reset it by using a bind plug in the battery port. Make sure you've set your transmitter to Random bind mode , sorry I don't know my way around the stock devo firmware, I use the deviation software, but you can't use it with the devo 7..
          Thanks tried using teh bind plug but even with the plug in battery port Im still getting a fast flashing light on the receiver. Having looked I think its meant to be a slow flashing light.
          Please someone help as I want to fly my new toy :-)
            I'm sorry to say ..looks as if something isn't working..either the transmitter or receiver..Make sure you're on random bind and you haven't set a bind id. Switch on tx then plug the help in immediately. .It should bind within 10 secs. .or there's something wrong with the hardware..sorry that's all the help I can offer as I don't own the model or that transmitter..just the 8s and 12s
