Hi guys I'm adding telemetry to my new trex500 using the tm1100 module and gpro fbl I understand how to wire to the tm1100 but which channel is which on the ar8000 one says gear which I'm assuming is planes a picture says a thousand words so I'll just upload one since I've probably explained that terribly basically I'd like to know if I've done this right? Also do the wires to to the bottom on the ar8000 or at the top of the plug it doesn't say in the manual
thanks
thanks
