Trex 700e HV receiver switch?
  • Trex 700e HV receiver switch?
    I recently purchased a Trex 700e HV, I'm running the electrics off a 2s RX 5000mah lipo and I'm wondering if anybody is using a receiver switch or are you just unplugging the battery from the FBL controller when switching off or any other method. I assume that if your using a receiver switch it would have to be able to take at least 20amps. Any info would be great,
    Phil
    Phil
    Align MR25 Racing Quad
    I don't use a switch because I just think that it is one more thing to go wrong. My rx battery is connected with an XT60 plug which I unplug after every flight. I have two connectors from the XT60 going in to the fbl unit.
    I should think that you would have to be throwing it about a bit to pull 20 amps but better to be safe than sorry.
