Hi guys,
I took out my new (to me) Trex 700e this afternoon and noticed something a bit odd, as I spool it up in normal mode the rpm rises they should until around midsticks where it falls slightly.
Then after taking off I switch to idle up 1 and there is no increase in headspeed, the same applies to idle up 2. The modes do take effect in as much as you can flip and roll so the throttle is constant even on negative pitch (we all know what happens if you do this in normal mode! Lol)
The heli is a stock Trex 700e (3g head) with the 700 motor and castle ice 120 esc. I know ideally I should set the esc up in governer mode on the laptop but a lack of dongle and a desire to fly sees me using throttle curves instead.
The esc is straight as it comes as the previous owner used throttle curves too.
Just for reference my throttle curves are as follows;
Normal: 0-80
Idle up 1: 80 flat
Idle up 2: 90 flat (did try 95 but no difference)
Am I missing something?
Gary
Normal: 0-80
Idle up 1: 80 flat
Gary
and a platinum star
