450 pro
  • 450 pro
    Hi everyone
    have finished building heli and put the pitch guage on blade at mid stick and its a bus ride out ,servos r at 90% and everything level ,question is which part do i alter to get pitch guage level with flybar at mid stick please
    many thanks in advance
    Raptor 50 , raptor 30 , eflite blade 500 3d, blade 450 3d, spektrum dx7s,
    hitec eclipse pro 7 tx with optima receivers
    Blade 130x with lynx upgrades
    raptor 90 under construction
    There should be only 2 adjustable links on the pro as the others are fixed length iirc
      Start at the bottom "ie" servos
      Servo arms at 90 degrees when you are at mid stick.
      Then adjust the links to the swash plate making sure that is level.
      Then the last stage is adjusting the two links that fasten from the swash to your blade grips making sure each blade is zero degrees on your guage.
        Thanks everyone for your help
