Anyone good at algebra?
  • Anyone good at algebra?
    I am doing a maths course atm and really struggling, maths is not for me. I have been stuck on this question all day!
    5
    -(a-2) = 10
    8
    Can anyone point me in the right direction to solving of a.
    Many many than in advance
    Darren
    Raptor 50 v2, trex 600n fbl, trex 550 v2 3gx, trex 450 3gx v2, mini-titan v1, mcpx v1, WoT4 foamE, Gootch 450, mcpx bl.
    Whats the equation? Can't understand it the way you've written it.
    TREX 700E DFC SK540
    TREX 550E AR7200BX
    Logo 400SE SK540
      Not sure if I'm reading the formula correctly, but if so then a=18, check that and if it is it correct then I'll explain how to get there, if it is wrong then please present the formula a little more clearly :)
        The equation if I got it right is
        5/8x(a-2)=10
        And if I'm right
        5/8 is 0.625
        So 10/0.625 = 16 + 2 =A
        Invertix 400
        Vortex 285
        TBS Discovery Endurance
        X4 II
        Schluter Champion Longranger
        G4 E720
        G4 E720 Big AIR edition
        Goblin Urukay super slow
        Goblin 700 KSE Slow
        Goblin 700 KSE Fast
        Srimok Faifa
        Spectra G
        Synergy 766
        http://mangled-rc.com/
          -(a-2) = 10
          8
          5(a-2) = 10x8
          5a-10 = 80
          5a = 80+10
          5a = 90
          a = 90 divided 5
          [B]a=18
          [/B]
            Hehe more then one way to skin a cat. :D
            Invertix 400
            Vortex 285
            X4 II
            G4 E720
            Goblin 700 KSE Slow
            Goblin 700 KSE Fast
            Srimok Faifa
            Spectra G
            Synergy 766
              Since we all seem to read it the same way, this was my approach:
              multiply both sides by 8 to remove the fraction:
              5(a-2) = 80
              divide both sides by 5
              a-2 = 16
              Add 2 to both sides
              [B]a=18[/B]
                [ATTACH=CONFIG]52734[/ATTACH]
                  [QUOTE=Obi Wan;945142]5
                  -(a-2) = 10
                  8
                  5(a-2) = 10x8
                  5a-10 = 80
                  5a = 80+10
                  5a = 90
                  a = 90 divided 5
                  [B]a=18
                  [/B][/QUOTE]
                  That's how I did it too.
                  Harry
                  Powered by Futaba 18SZ
                    Re: Anyone good at algebra?
                    Brilliant! As you say Joe many ways to skin a cat. The penny has dropped....well nearly.
                    I am still a bit confused by the line...multiply both sides by 8 to remove fraction. I understand but......
                    5
                    If I times by eight that just cancels out the fraction and just leaves the numerator hence 5(a-2) = 80?
                      5/8x(a-2)=10
                      that is the same as writing
                      (5(a-2))/8=10
                      Expand the bracket on the numerator
                      (5a-10)/8=10
                      now multiply by the denominator to give 5a-10=80
                      add 10 to both sides : 5a=90
                      now divide 90 by 5 to give a... which is 18
                      so yes in short what you have said is correct 5(a-2)=80 : when you expand the LHS to give 5a-10=80 it is much easier to solve.
                      Tried to explain as thoroughly as I can hope this helps :)
                      Gaui X5 - Spartan Vortex
                        Is that something to do with painting by number cos i can do that :emmersed:
                        • Flickr Through My Pictures.
                          If you have something divided by 8 and then you multiply by 8 (effectively doing the opposite, or inverse in mathematical speak), you end up with 1. It doesn't disappear as such, but if you multiply something by 1 nothing changes. Easier to show than explain.
                          (8) x [U]5[/U]
                          8
                          Which would look like:
                          [U]8 x 5[/U]
                          8
                          The 8's cancel so you end up with:
                          [U]1 x 5[/U]
                          1
                          Which effectively just leaves you with 5. To balance the equation you must also multiply the other side by 10, which gives you
                          5(a-2) = 10x8
                          and someone else has already explained it from there.
                          Simon
                          Trex 700N & E
                          x 2
                            Theres tumbleweed in our living room while i try to get my head round that lol ;)
                            Avant mostro 700E
                            Avant mostro 700 Nitro
                            member of :
                            South cheshire heliaddicts
                              Thanx Stanley. I get it...just practice now to ingrain it.
                              Tell me about it Tony. I am two months in to my degree and I thought flying heli's was hard!
