Can anyone on here make brake caliper pistons??
  • Can anyone on here make brake caliper pistons??
    As the title says basicaly. It's either that or buy another set of calipers & risk them also needing pistons, buy new piston & seal kits at £140 for all 8 pistons & seals, buy Nissin 4 pots & have to buy new goodridge hoses 'again' & get someone to make mounting brackets. So is anyone a bit handy with a lathe or whatever you use to make such type of piston.
    £140 sounds cheap to keep yourself alive.
    Happy Landings.
    David
    Raptor 50. OS50
    Mcpx
    Blade 130x
    Goblin 500
      [QUOTE=p4ddy;941051]As the title says basicaly. It's either that or buy another set of calipers & risk them also needing pistons, buy new piston & seal kits at £140 for all 8 pistons & seals, buy Nissin 4 pots & have to buy new goodridge hoses 'again' & get someone to make mounting brackets. So is anyone a bit handy with a lathe or whatever you use to make such type of piston.[/QUOTE]
      What do u want the pistons for?? Most motorcycle applications are lightweight low compression alloy with a special coating, Cars are generally steel, but in high end cars that can be alloy.
      Collector of SAB Goblins
        [QUOTE=David Drew;941156]£140 sounds cheap to keep yourself alive.[/QUOTE]
        True but everyone on my bike forum say's it's too much???. They all say get some nissin 4 pots for £50, thing is i then need everything else with them bumping the price up again. There's some stock calipers on ebay but i risk the pistons also being fooked & i'm back to square one. I guess i'll just get all 3 calipers done so they'll efectively be brand new original calipers
          [QUOTE=KevDavies;941160]What do u want the pistons for?? Most motorcycle applications are lightweight low compression alloy with a special coating, Cars are generally steel, but in high end cars that can be alloy.[/QUOTE]
          Gsxr 750G
