Hovercraft
  • Hovercraft
    Hi
    Does anyone know of a good RC hovercraft or where I can find plans to build one.
    Mack
    Thought I was finished with the crashing thing!!
    Check out
    [url]http://www.hovercraftmodels.com/[/url]
    Dave
      Thanks Dave
      Once you start looking there is alot available. Do you know what channel should be used for them. Same as cars, or same as planes?
      Mack
        Hovercraft are surface vehicles so can use 27mhz band or 40 mhz band
        Dave
          Only just saw this but my Son and I built a Griffon 2000 from plans on the internet [url]http://www.model-hovercraft.com[/url] about 2 years ago.
          two 600 motor and speed controllers. Use the throttle and aircraft speed controller for lift and boat/car (with reverse) on elevator stick for forward and back.
          Goes well on water, I had trouble finding material for the skirt but saw another at a show and owner advised he used groundsheet from an out of town camping supplier. This did the trick.
          Hovercraft works well on wet grass or water but not anywhere else.
