scorpion component ID
  • scorpion component ID
    My black and decker scorpion has packed up and is out of warranty and iv just disassembled and tested it with the multimeter and there is power right through the brushes to the motor but stops right where the black capacitor type thing is (see pics).this component is connected to the left side brush only . Can any one ID this component ?and is it possible to fix/bypass it .
    Twister 3d storm
    MCPX v2
    DX6i
    Hi Looks like an RF Choke to help stop radio interference surprised that you are not getting a circuit past it as usually they are just a coil of enamelled copper wire wound around a piece of ferrite rod.
    Try shorting it out and see if you have got a circuit. B&D don't make the best or most reliable of power tools check out the trigger as well especially if it's the variable speed type.
    - TREX 600esp - TREX 600e - TREX 450 Sport - Eflite Blade MCPX - Eflite Blade MSR -
    - DX7SE - DX9ii - Pheonix -
    * Loads of Gear & Still No Idea *
      take the peice out and take it to a maplins store they will be able to help you
      Raptor 50 v2
      Raptor 50 titan se
      Raptor X50n to go in sea king fuz
      Raptor 90
      dsx9 mk2
      600 size Sea king being built
      Bo-105 in red bull colours waitng to be built
        [QUOTE=dave j;710324]take the peice out and take it to a maplins store they will be able to help you[/QUOTE]To be honest Dave , the guy,s in the York Maplin couldn't find there arse with two hands . I went there 2 days ago for some heat shrink and a deans connector ........their reply was "what are them":ack2:
        Twister 3d storm
        MCPX v2
        DX6i
          ok just retested with an electrical screwdriver. there is power from the trigger to the lower half of the motor and to the right side brush , but the top half of the motor including the left brush with the choke attached is dead
          Twister 3d storm
          MCPX v2
          DX6i
            Short it out it will work fine it will just make a big more electrical noise
            Steve...
            Outrage RC Field Rep
              :ack2:[QUOTE=xygax;710385]Short it out it will work fine it will just make a big more electrical noise[/QUOTE]
              Hooligan.:)
              It can be repaired. Just find the wire gauge and wind some wire round the core. Its only an electromagnet. Or you can count the turns and so long as we know the rating of your drill we can find a replacement.
              Can you give the full part number of your scorpion. Black and Decker do an exploded parts list. Haven't found your component yet.
              Blade 130-X, MSR, MSRX
              Phoenix Sim
                Its the gel tech scorpion - model KS890GT type 1 - 400w - 50Hz . Does this component stop the brush working ? as there is no currant detected before this on the motor . the way it is set out is .......the right brush is connected to the lower half of the motor and all this is live once i depress the trigger . the left brush is connected to the upper half of the motor and all this is dead even if i depress the trigger . hth:cheers2:
                Twister 3d storm
                MCPX v2
                DX6i
                  If it is a coil and in series with the motor then it will stop it working as the current can't get through it. I'll try and find the replacement. If it is in series then you can short it out with some fuse wire. If it was in series it will work, if not the fusewire will blow. Don't be too close when you tru this and use an RCB.
                  Phoenix Sim
                    Looks like it might be one of these.
                    BDE-573185-00.3
                    That's a brushbox and choke. I'm not sure from a distance, but it looks as though it will work without it. Not sure why it would fail though, unless it also acts as a safety fuse. Might be an idea to get another or repair the existing one. It's a cheap part. You could certainly short it out to see if it gets the saw going. But there's probably a reason why it failed, and that same fault could happen again.
                    Phoenix Sim
